I've gotten this shake to my motor that has gotten worse within the month. I suspect a bad engine mount of mounts.
I've got a question, to do this job will I be able to put my 1992 on jack stands(2 on the front) and then with a jack and a piece of wood, jack it up to raise the motor a bit by the oil pan(after removing the bolts to the mounts)??
This shake happens at idle, then when doing about 70 my front end seems to start shaking again.
