Lose weight first.,its tight in there....lol.. seriously, get the spacer pattern from Toobroke, I had to reduce it 5% on my printer to be perfect. lay out on any material you choose that's minimum 3/8 thick. cut out. remove old blower wheel, fit spacer on motor, be sure you have plenty clearance for new wheel. glue and/or screw together .drill bolt holes thru spacer, . grind ,sand about 1/8 inch out of the hole in blower hsg. .. remove wheel before placing motor in fenderwell.. reassemble in fenderwell. [ IT WILL NOT GO IN THERE ASSEMBLED, or at least I couldn t get it in] place motor/wheel in housing, start screws [ need 1/2inch longer screws now] turn on fan to be sure it doesn t rub anywhere.. tighten screws , check for leaks reconnect hose to motor ... I sealed everything on mine with silicone .. did that help? now enjoy about 40% more cold air in your face... OHH one last thing, remove the Expansion tank bottle!!
