I don't know about texaco gas but I can tell you for sure that shell gas will screw up the float. I only run mobil or BP gas. I only had to add techron every couple of fill ups and never had a problem.
drivers side ... this will show you all you need ...I would replace the pump while you are there if you have many miles on it.. http://lingenfelter.com/pdf/c5fuelpumpinstallationinstructions.pdfI've read threads & posts on this until my eyes are falling out, but I need a straight up, no-$hit answer
Which side is it that takes a crap to zero out the fuel gage when bad fuel has screwed up the float? I've been playing the Sea Foam, Techron, Gumout game for over a year now, and running nothing but Shell or Texaco gas with the highest octane I can find and I'm tired of it.
I'm feeling froggy and want to jump, so which side tank do I crack open?
:thumbsup: Thank youdrivers side ... this will show you all you need ...I would replace the pump while you are there if you have many miles on it.. http://lingenfelter.com/pdf/c5fuelpumpinstallationinstructions.pdf
