I need help with this - wipers went up and never came down - cleaned out the udders and found 2 wires that I can see the copper - put tape over that - disconnected the motor, then I disconnected the pump - fuses still blow - this happens without even putting the wiper switch on - all I do is put the ignition in the on position and the wiper fuse blows - has anyone ever had this problem and can you help?
make sure the copper wires you taped don't have any strands touching metal or strands from the other wire. You could also have a bad wiper motor.
but he said the motor was disconnected.....weird......
