Wiper Problems
1633 Views 3 Replies 2 Participants Last post by  toobroketoretire
I have an 1981 Corvette and my wipers run all the time, I replaced the switch in the dash with a new one, I replaced the ground wire from the engine motor to the frame with a new one, I bought a jumper wire plug to bypass the delay wiper relay, and the latest I replaced the wiper motor it self. The wiper switch seems to have no effect on the system at all, low, high, delay, nothing works, the ground wire was cut off so replaced that. the delay relay switch is original and will make a few clicks and work very rarely but with the jumper plug in place the wipers will run all the time. and the new wiper motor works and runs smoother than the old one. and help or suggestions would be great.
Thanks Randy
1 - 4 of 4 Posts
Thanks Randy
What are you talking about when you say "jumper plug"?
Hi the " jumper plug " is a by pass wire for the delay wiper relay that sits in the storage compartment behind the passenger seat on the 81
Thanks
Thanks
Can you take a picture of it? Because I still have no idea what you're referring to.
1 - 4 of 4 Posts
