OK guys need some help here?????
Test 1 Vacuum test on all actuators relay's came out great. Vacuum tank is also good along with all lines and valves
Test 2 If I pinch off the two big lines to the headlights then wiper door works ok but not as soon as you start the motor but will work. I can remove the pinch offs and all will work but if I cut the motor off and re-start nothing will work until I pinch them off again.
Test 3 What am I hearing? I hear the vacuum like leaving the tank?
Test 4 Chase it down to the wiper door unit. Actuator relay tested good. If I pinch off the red and green hoses or even the main large one then vacuum stays up and head lights work. But if I cut off the motor and then back on I have no vacuum.
Test 5 Put my hand over the black plug on the front of the wiper door actuator and could hear the vacuum loss slow down some. Can't do that to well on the rear.
Looked at the rear of it where the rod comes through to operate the wiper door and looks like it has a rubber like seal that you would think would help seal the rod but it is very loose both side to side and up and down and just like it is doing nothing?
Looks to me like the wiper door actuator is releasing all the built up vacuum in the tank and the motor want build the vacuum back up quick or at all. Motor at idle is pulling 18" of vacuum so I think that is good.
After reading an article I think the problem is the seals on the wiper door actuator and I can buy a kit with all 3 pieces to fix it. But before I do I wanted to check with you guys and see if I am on the right track?
Thanks
Thanks
