I've never tried that application method so I have no comments . . .
Wax Application (Notes)
1. Because a dry cloth absorbs liquids, application with a dry cloth will result in the absorption of the wax as opposed to spreading it on the surface, use a damp applicator (similar process to pad priming)
2. A Microfiber towel made from polyester (the scrubbing and cleaning fibre), and polyamide (the absorbing and quick drying fibre) will adsorb (hold onto) liquids due to its inherent properties, their unique wedge shape of the cross-section of each of the fibres, which enables them to slice into coatings lifting and removing them from the surface (much like a miniature squeegee) as they are wiped across the surface.
3. The nature of this yarn is that it is an absorbent; the reason polyester appears to adsorb liquids is the many thousands of micro fibres that collectively encapsulate liquids.
4. The correct method for the application of a wax and to obtain optimum results: is to apply it very thinly. Ease of product removal is inversely proportional to the amount used.
5. Buffing - Swisswax 100% cotton micro fibre towel with a terrycloth weave, spun with long staple cotton and then woven into 100% natural looped terrycloth or velour, were the loops are trimmed to produce a blunt fine nap, which is ideal for removing wax and for final surface buffing
