I have been toying with the idea of using an O2 sensor to help me get my jetting, vacuum advance, and distributor curve dialed in. I installed an O2 sensor into the side of my gutted cast iron heat riser valve, connected a digital voltmeter, and took it for a spin. My first run indicated my cruising air/fuel ratio was around 13 to 1 using #72 primary jets so I came back home and changed my primary jets to #70's. I took it for another spin and it indicated my cruising air/fuel ratio was now 14 to 14.2 to 1. I also found my full power air/fuel ratio was around 12.5 to 1 so I drilled my secondary metering block .003" larger. Then to increase my vacuum advance's total I lengthened the slot another 1/4" and now it'll produce 16 degrees of advance; 4 more than the 12 degrees it had.
So yes, you CAN use an O2 sensor to help get your fuel mixtures where you want them to be. Now that I've found my fuel mixture changed dramatically with a simple jet change I'm now in the process of adjusting my vacuum advance and distributor curves to obtain a more aggressive advance rate. With some further tuning I'm hoping to achieve a 14.7 to 1 air/fuel cruising ratio.
