My friends 2003 Anniversary Edition automatic transmission is leaking.
The transmission was pulled and new seals installed. The front oil pump has a hairline crack and was replaced. Transmission still leaks the red fluid on at the front weep hole and on the right side running back to the cooling fins on the transaxle.
Any one had this experience with any ideas.
I had it on my lift and can't see where its coming from.
Thanks
Might look at the cooling lines real close. Fluid can creep around from every which way and there are many sources for a possible leak on the lines/fittings, etc. Even a cracked line.
