Does anyone know how much difference a transmission cooler really makes? I have had two almost-new A/C condensers sitting on my shelf for about 15 years so I finally mounted one on my '71 with it's TH700R4 transmission. After studying the various coolers that Summit Racing stocks I see mine is built much the same way and using the same materials so it should work perfectly. Mine has 130" of 3/8" copper tubing arranged in double rows but I don't think that makes much difference as I'm only using it to supplement my radiator's cooler.
But how much difference will it really make? 10 degrees? 20 degrees? When I come home from the valley I have to pull a 10-mile 6% grade and I'm sure that hard pull really heats my oil up way beyond what it would see during flat-land cruising. Most of the time I run the majority of it in 3rd gear at 1800-2000 rpm to take some of the load off my engine as my speed of 45-50 mph is just enough to allow running in 4th.
