Help!!!!!!
My timing chain jumped so that my 87 was trying to fire on #4 so I went through the ordeal of installing a new set of gears and chain.
After making sure #1 was TDC I proceeded to detach the EST and set my base timing @ 6 degrees BTDC I shut the engine down, re-attached the EST, and disconnected the negative battery cable for at least 5 minutes re-installed the negative cable and started it up and it runs like crap.
Any help appreciated.
