Dittothrowing parts at a engine rarely gets you max HP
it all has to match up
eadHorse:I just ordered a M A F which increases the Air Flow from 644 cfm to 1000 cfm has any one tried this? Also a flow wedge for the intake. Advertised as a H P kit for LT's . The intake area is increased from 75mm to 80mm I have a K&N filter up front and muffler eliminators out back { no mufflers} I think more air in more power out. RIGHT. Anyone try it:thumbsup:
yes it will do something , kill bottom end :rofl:As a former professional engine builder I'm going to give you some sobering figures.
1. A 350" engine that is 100% volumetric efficient will consume 608 cfm at 6000 rpm.
2. At the very best street engines will only reach a 80-85% volumetric efficiency because of their "streetable" intake systems, cylinder heads, camshafts, and restrictive exhaust systems.
3. At an unrealistic 85% volumetric efficiency that 350" engine will consume 517 cfm at 6000 rpm, 474 cfm at 5500 rpm. and only 430 cfm at 5000 rpm.
Adding a MAF that CAN flow 1000 cfm won't do anything unless the other components are replaced with equally high-flowing components. And then to take advantage of the increased revs you'll also need rear end gears like 3.70's or lower.
NOPEyes it will do something , kill bottom end
:rofl:NOPE
The new MAF has 1000 cfm flow " potential " but as noted above the engine will still only suck as much air as it requires so no change in perf
then it would make sense to just make the stock one open quickerNow, a larger throttle body will give a noticeable increase in response but nothing in additional power. Why? Because for each degree of throttle plate opening more air can flow which would be the same as opening a stock throttle body more.
Will make no difference because with his stock setup a larger MAF as already noted is not going to flow any more air than a stock onego try it on a dyno and get back to me.......igsfly:
Once again ; no difference .Watch what happens when you go full throttle. it will fall on it's face.
eadHorse:I just ordered a M A F wich increases the Air Flow from 644 cfm to 1000 cfm has any one tried this? Also a flow wedge for the intake. Advertised as a H P kit for LT's . The intake area is increased from 75mm to 80mm I have a K&N filter up front and muffler eliminators out back { no mufflers} I think more air in more power out. RIGHT. Anyone try it:thumbsup:
WhateverAt part throttle , it makes a difference.......unless you slow down the blade
In this case , it disproves the commonly held myth that a larger TB will let too much air inWhat does an ET prove ?
The aftermarket MAF is not "designed " for a larger engine ; it just claims to be less restrictive than the stock one and because everyone knows stock parts suck ;I can't see how a MAF designed for a larger engine could do anything beneficial.
