My tach is bouncing around quite a bit. Any suggestions. '75
Lethal Tendencies · Super Moderator Joined Mar 30, 2007 · 5,586 Posts Discussion Starter · #1 · May 26, 2013 Only show this user My tach is bouncing around quite a bit. Any suggestions. '75
USNChief · Registered Joined Nov 30, 2009 · 3,154 Posts #2 · May 27, 2013 Only show this user I have a 1980. I replaced the tach filter and make sure you do not have any loose connections.
Lethal Tendencies · Super Moderator Joined Mar 30, 2007 · 5,586 Posts Discussion Starter · #3 · May 27, 2013 Only show this user Where is the tach filter located ?
[email protected] · Premium Member Joined Jun 7, 2009 · 9,061 Posts #4 · May 27, 2013 Only show this user on manifold next to distributor ..they do go bad and cause problems,or could be a bad connection... this is it http://www.mamotorworks.com/corvette-c4-c3-tachometer-filter+1975+1989-1-140-5902.html
Lethal Tendencies · Super Moderator Joined Mar 30, 2007 · 5,586 Posts Discussion Starter · #5 · May 27, 2013 Only show this user Very good , thanks
Lethal Tendencies · Super Moderator Joined Mar 30, 2007 · 5,586 Posts Discussion Starter · #6 · Jun 1, 2013 Only show this user Filter was the issue. Thanks
[email protected] · Premium Member Joined Jun 7, 2009 · 9,061 Posts #7 · Jun 2, 2013 Only show this user :thumbsup3:
