Has anyone done this conversion? What all is involved, any pics or links? Thanks!:thumbsup3:
it's just a straight foreword swap from what I've read. You'd have to get your drive shaft shortened a bit and you'd have to alter your throwout arm. I don't know what size of yoke it uses on the rear but I'm sure your drive shaft people can get you set up with whatever you need.
a couple people have..but, I think you will find that the 6 th gear [.6 overdrive] is useless in a heavier C3 with small rear gears and a powerband not suited for it..
I have been looking at this upgrade as well. A mechanic friend of mine told me to skip the T-56 and stick with a T-5. He said the T-56 would rub the tranny tunnel unless it was modified.
Now if I could just find time to work on it.
Most of the guy's that have made this conversion did it with an LS-1 swap.A few have put it behind their old motors.I can't remember who though.Im gettin "Oldtimers" and my memory leaves me.
Six Speed Transmission
Assuming he has 3.08's in the rear the 6th gear would yield about 1200 rpm at 60 mph. I think a 350" engine would pull it but it would definitely be a dog. Almost too tall. But 5th gear would be perfectly usable as that's only a 30% reduction. Now if he were running 3.73's or 3.90's in the rear it would be pretty slick. I'd say if the transmission was cheap enough I'd give it a go and see how well it works out.
