Strange Beep in Dash
1790 Views 2 Replies 3 Participants Last post by  vettex2
I have an annoying beep/buzz that sounds like the old fashion headlight warning buzzers. It comes from behind the dash in the radio/AC vent area. Beep lasts for about a second (sometimes longer) and occurs after the car has been running about 2 minutes. Typically one beep then nothing. It will not do it again until the car is turned off and restarted.
The buzzing went away for a short time but it is now back but with a twist. Today when I turned on the turn signals it beeped on and off in sync with the turn signals.
Car is a 2000 Coupe (A4, Z51) and has the original radio/CD player. It throws no codes and has no known electrical issues.
I did a search and found some talk of the hazard switch causing problems with the brake lights and turn signals but those work fine. Any thoughts?
Never heard of that. There really isn't anything in there that would make a noise. The stereo , hazard switch, vent is about all that's in that area.
possible flasher ?
