Strange Beep In Dash
2552 Views 3 Replies 2 Participants Last post by  Lethal Tendencies
I have an annoying beep/buzz that sounds like the old fashion headlight warning buzzers. It comes from behind the dash in the radio/AC vent area. Beep lasts for about a second (sometimes longer) and occurs after the car has been running about 2 minutes. Typically one beep then nothing. It will not do it again until the car is turned off and restarted.
The buzzing went away for a short time but it is now back but with a twist. Today when I turned on the turn signals it beeped on and off in sync with the turn signals.
Car is a 2000 Coupe (A4, Z51) and has the original radio/CD player. It throws no codes and has no known electrical issues.
I did a search and found some talk of the hazard switch causing problems with the brake lights and turn signals but those work fine. Any thoughts?
1 - 4 of 4 Posts
We're you able to figure out what the beep was?
Finally figured out it was the Hazard Warning Switch in the center of the dash. Seems like there is a small relay in the back of it that was going bad. After replacing the switch no more problems.:thumbsup3:
That's cool. I know the switches go bad I never heard anyone complain of a relay hum or beep.
1 - 4 of 4 Posts
