I have been having issues with my starter... it makes this nasty loud grinding sound after a few months of having it on my car. I have gone through 4 starter solenoids in the past 2 years (2 per year pretty much) and it's getting annoying to swap it out and im confused as to why it's doing it... I rarely drive my car and I turn it on at least 1 time per week or 2 weeks and leave it running for 5-10 mins. OH BTW I installed a Starter Solenoid Shield thinking it would fix my issue cause maybe it was getting hot with my headers and it DID NOT fix my issue but I still install it on them anyways.
The starters all get the same issue (btw 2 of them were rebuilds from a reputable starters/electric shop and 2 of them were NEW Remy AC Delco) which is the starter solenoid does not engage & spin at the same time (which is the power post) I've done this test with the starter directly to a battery and if I hit the negative post it spins, if I hit the ground post it engages, but if i hit the positive post it does not do anything. Again all these 4 starters have had the same issue.
Is their something I should be looking for to fix this issue... im tired of swapping out these heavy starters!!
If you need more info or diagnosing let me know so I can get that info for you, thanks!
