Removing Speedometer Needle
Does the speedometer needle just pop or slide off, so I can replace it?
I pull mine off by laying a short piece of 3/16" key stock on both sides of the needle center then I use two putty knives to pry (lift?) the needle off. It is just pressed on about 3/32". To put it back on get it set into position and give the center a couple of light taps with a tiny hammer (like a tack hammer).
