I have a ZZ4 in my '80 C3 It has fastburn 383 aluminum heads with 1.6 roller rockers and hooker headers. I would like to get some header plugs with platinum or something. Not really buying into the E3 spark plug thing but what's the best plug to use? I didn't know if I should go up in heat range or down or stay the same. Since it's not a stock engine or stock ZZ4 at that.
As always thanks in advance!!!
are the aluminum heads taper seat or flat w/ compression washer? you can get a short header plug from Accel for header clearance...the engine builder should have a recomended heat range for your motor.. typically, higher compression performance engines require colder plugs, [thats a lower number ,except NGK which is opposite]. I run a very short,cold plug ,Autolite AR3932 . its for a flat seat alum head, hi rpm high compression application
As your ZZ4 has a 10:1 compression ratio I'd use stock AC Delco plugs that are one step colder.
Thanks I found the P.O. had two different types of plugs in this thing :banghead: one was iridium (spelling) one was a platinum and the others were regular ac delco.
That scares me
forget the iridium..Autolite Platinum or AC Delco is plenty good ... do you know what heat range was in there before the upgrades? Start 1 step colder.
Discussion Starter #6
I'll take a look at them also if there are different heat ranges on each plug (which should surprise me but not now) then read the plugs.
I've always been a Platium fan manily because I've never had or used the iridium plugs
