1 - 8 of 8 Posts
Smokin Vendor
Lately i have been driving in my competitive driving mode for the past 2 weeks and for the past 2 weeks my service traction/ABS lights have been coming on. It does reset but has come on at least 5 times in 2 weeks. Is something going or is the driving mode making the system sensitive? Any feed back welcomed
pull the codes
that is not good
possible EBTCM module
check the connector udner the hood to the abs and check the grounds
make sure ieverything is clean and tight
you might wanna pop it open and clean it with contact cleaner and then see what happens.....
they are only 150-200 bucks rebuilt
The only problem is that the rebuilt is better than the new one
the oem solenoids fail
the aftermarket ones don't
1 - 8 of 8 Posts
