Started reinstalling my interior. Having a problem with the seat cushion. I got them off no problems but I cant get he new ones back on. Is there a trick or special tool that I need to get the new cushions on the seat frames?
the covers are on. i was asking isf there are any tricks on getting the cushions on to the seat backs and seat bottoms. manaul says to use a v notched tool. to push the bars past the clips. i notches an ould screw drives and works great.
second question: i removed the seat rails to sand blast and refinish. one seat of rails is taller then the other. which on goes on what side?
thanks to broke. one seat is taller then the other cause one of the rails is taller then the other when bolted to the bottom. which seat goes on what side?
i found a set of seats on Ebay and the taller seat rails are on the drivers side.
Great advice, since if that is the case on your car no matter what side you put your sliders on the chrome balls will always be on the right side, but that has nothing to do with which one goes on which side. It just illustrates the way you think.The seat-adjust chrome balls both go on the right side...................
