Haynes pg 10-14 or the FSM, very complicated procedure, and the airbag must be deactivated.........
Slick, thanks for your help, as it turns out removing the cruise control lever/ turn signal / windshied washer assembly is fairly easy. The lever wiring harnish for the lever is outside the column so all one has to do is unplug the harnish and pull/yank the lever toward the driver door and walla its out!! If only everything was that easy. Thks again..Haynes pg 10-14 or the FSM, very complicated procedure, and the airbag must be deactivated.........
