RE: Summer upgrades
My upgrades for the summer are almost complete. The shop ran into a few snags along the way.
Went with the .408 stroker using my stock block, mild cam, stock ported heads, upgraded fuel system, z51 front rotors, painted (red) calipers, transmission brace, centerforce TD clutch, and a few other minors.
While on the dyno, the V-3 Si ate itself. Damage was so bad that I couldn't even rebuild it... you couldn't even turn it by hand at ALL once it was taken off the car. I ended up getting a new one from Vortech. Was disappointed as the blower only had about 12k mi. on it. Better on the dyno than on the street. Vortech did give me 400.00 off on a new one though. Also, with the damaged V-3, it still pulled 692whp!
After receiving the new blower, the car was being moved onto the lift and an oil leak was discovered. They had no idea where it was coming from, so they pulled the engine and tore it down to the core. Found out that a setting on the oil pump was in the wrong position. I was a bit po'd, but the silver lining was that they also found out that 2 of the pushrods were bent and there was a chip on one of the pistons. These parts were all brand new btw. The shop sprung for new and even better pushrods and even deeper dish higher quality pistons.
Should have everything buttoned up and on the dyno by tues/wed. Will post new dyno #'s by Friday. Looking to get 750whp.
