The rear is most likely to snap at launch. Wheel hop seems to be the big killer. If you are doing roll ons using street tires, I'd be inclined to leave the rear alone until you actually break things.
The Z06 rear is stronger than the base. Occasionally you can find someone with a Z06 that will swap with a regular rear (plus some cash) as part of doing a gear change (I don't know if someone finally came out with a 3.90 ring and pinion for the Z06).
Some shops just beef up the shafts on a rear rebuild, but others go well beyond that. At 700 RWHP, if I opened-up the rear, I'd probably go through it more completely.
