I put a 1972 mild 383 stroker motor in my 71 vet , my kids bought me a water pump from summit , any way I dropped the motor in and I noticed the shaft on the water pump is 5/8 and my cluch fan has a 3/4 inch hole I assembled it with the old fan ,I have it running got the over heating problem solved runs nice and cool under 180 degrees . My question ,is this dangerous ? Should I put on a flex fan that fits the 5/8 shaft on water pump? Or get a spacer that would fit in the hole of the clutch fan and around the water pump shaft.or replace the clutch part with one that fits the water pump shaft and attatch the stock fan.any ideas
