My blinkers when turned left had been blinking really quick, so I picked up some bulbs. Sure enough it was the front driver side that went. Well after I changed the bulb and I put the switch down for left turn, nothing is happening now? Nether front or rear is blinking? The bulb was new, I even changed it out again and still both front and rear will not blink at all.
Any suggestions please?
Did you check your fuses?
I might be the actual switch. Does the blinkers work the other way?
That is weird that both front and rear aren't working now. I would start looking at fuse or switch.
