1 - 4 of 4 Posts
Hey Guys
The little switch on the side of the master cylinder, with the one-wire connection, is this for the fluid level?
Rgds
Theo
On a 90 it is for the proportioning valve located in the master cylinder. Fluid loss in the front or rear brakes will cause the valve to move grounding the switch & illuminate a dash warning light.
I agree , as it is that way for almost all cars
I believe the res. sensor wire is separate
1 - 4 of 4 Posts
