This will be difficult to describe. The blower motor in my 2005 is stuck in the defrost mode. When I try to redirect the flow (face, floor,defrost) nothing happens. The graphic of the sitting person toggles all functions but the control is stuck on defrost. Also, the fan is stuck on high and can't be adjusted. When I do a restart the fan resets itself. Please help!!!
Made give it the old microsoft fix. Reboot it by either pulling the fuses or disconnecting the battery for 20 minutes. If you pull the battery, you may need to reindex the windows.
I had some similar issues .I disconnected the battery for a couple minutes and when I hooked it back up I was good to go .The problem maybe in your memory (sorry ,cars memory ) .the procedure erased it .Also I have never had to re-index my windows but even that is pretty simple .
