I have a 3 wire system with a case ground. My antenna wires are GREEN; GREY; WHITE;
Need info as to what wire does what, and also have no power on any of them with radio on, could use radio and power antenna diagram please. My mitchell diagram does not cover the radio. Fuses are good at fuse box!
gray and green up green has voltage
white and gray down white has voltage green is ground now. if i remember correctly pink is power from radio and is hot in run orange is hot all the time both go to antenna relay
hope this helps
