1 - 4 of 4 Posts
Greetings. I have been working on the passenger side for weeks and finally got it all back to gether but now the window will only roll up about 90% of the way. I did put new guides on it but is there some other adjustment possible?
The directions are both in the factory service manual and the Assembly Instruction Manual. Sounds like the stops are in the wrong place, or maybe the gear on the arm is running out of travel.
You said "roll up" so are you saying it doesn't have power windows? With the aid of a good strong flashlight you can see down in there and see what is preventing it from going all the way up.
Thaks everyone - I have now been told it is probably the man gear so I am going to pull it and see what's up.
1 - 4 of 4 Posts
