21 - 40 of 53 Posts
Discussion Starter · #22 · (Edited)
here are a few more things that are for sale
1984-1990 MAM Z51 air dam. The drivers side things that the bolts go through were notched but can still be bolted up. These are new and have never been on the car while it has been driven. 25.00
1990 (only) manuals 50.00
Discussion Starter · #28 ·
this is a california legal full 1990 exhaust system. It has about 5-6 hours of idle time only on it, it has never been driven though. It is a magnaflow system and has the CARB numbers on it. The catback came from corvette central (I think) they are magnaflow stainless with LT1 tips. The mufflers can be polished easily.
the main cats shield was turned around so CARB numbers can be read from under the car.
I was going to try and adapt this to my 82 corvette but have decided to just buy a new system for it.
550.00 gets the whole system and I prefer not to ship as it wiould be expensive to do so. System can also be polished for extra.
Discussion Starter · #30 ·
I am also packaging factory bolts and retainers for specific parts from this car and they will be listed as well.
No bolts from the motor or suspension will be available though.
If you are looking for specific bolts let me know.
Discussion Starter · #31 ·
Right rear wheel house, no cracks
30.00
Underhood braces all 20.00
wheel house left and right no cracks 50.00
hood locks and correct 10mm bolts 15.00
wiper motor bolts 5.00
These plastic insert where you screw bolts into that hold the top of the front bumper cover on each side 10.00
these are for the hood latch support arm that comes up from the frame and the odd bolt is for a 90 ecm mount 10.00
these bolts are for the front fenders right in front of the doors. These secure the bottom of the fender 1.00
these are 10mm wheel house bolts 15.00
Torqs screws for fenders and under hood wheel house shields 25.00
Discussion Starter · #32 ·
Plastic wiring loom holders, these came from brackets on the side of the bumper cover. 10.00
these are for 10mm fine thread 5.00
Hood bumper adjustments these were near the side of the bumper cover 10.00
these were the bolts and shim used for the the right front wheel house support 5.00
10mm small washer wheel house area 5.00
10mm large washer wheel house area 5.00
Discussion Starter · #33 ·
1990 bose amps, excellent condition and work fine. Two fronts and one rear, I have another rear but it is from a 92-up it works off and on.
GM P/N 16137240 16137243 16137242
these are correct for a 1990 and have the soldered wires verses the pin connectors.
160.00
21 - 40 of 53 Posts
