1 - 9 of 9 Posts
have oil change on 99 vette today, after that oil pressure shows 130 psi. can you help ? what wrong with it?
oil pressure sensor.....it's a wear item...lol
Discussion Starter #6
oil pressure gauge shows 130 psi.
thank you all for helping me with your quick reply.i will try that today.
Check the filter, may be wrong type or it could be defective (there should be a spring loaded bypass to prevent this in case of failure). I've heard of a C6 with a blown engine because of this.
If it still does it with a new filter, then check the sensor.
I agree. Too much of a coincidence that it happened at the same time as the oil change, although anything is possible.
1 - 9 of 9 Posts
