Picts Updated: 3/8/13
These are all parts from my barn find 69. Over 95% of the parts listed are direct from this 350/350HP machine... I went my own way with the build and did not use most the original parts.
I have listed these by a number. I have also made a link to all the photos below. Since there are so many I just published it this was as putting them all here would have been a mess. Also a few items such as the center caps and rings, jack, etc I had not taken picts of. If interested PM with email and I will send picts then.
SEE PHOTOS HERE: sdrv.ms/XHfuV6
I will only charge what it would cost me to ship depending on the part. And will fulfill requests ASAP. I do have a day job so please give me a little room to pack and ship (not Zip Corvette after all).
If you have any questions, please PM me as this thread may get large. Once a item is purchased I will make it sold on the post. Also, PayPal only. Sorry guys but don't wish to deal with checks or cash.
PLEASE NOTE THE ITEM NUMBER WHEN ASKING OR PAYING FOR PARTS ON ALL CORRESPONDENCE. Thanks!
Item - Description - Price New - Price Used
1 OEM Interior Wiring Harness & Engine Harness $689.00 $250.00 REDUCED! - $150
2 OEM Door Harness (Power Windows) $159.00 $100.00 REDUCED! - $50
3 OEM 350/350 Distributor (Fully Rebuilt W/New Parts Original Distro REBUILT NEVER USED) $399.00 REDUCED! - $299
4 NEW NEVER USED Chrome 45,000 Colt Coil $40.00 $35.00
5 NEW NEVER USED Pretronix Module (Sold with Distributor Only) $0.00 $0.00
8 OEM QuadJet (FULLY rebuilt and refurbished) $360.00 $250.00 REDUCED! - $200 - SOLD
10 OEM Steering Wheel (Very Good Condition) $269.00 $125.00 - SOLD
11 OEM Center Console Plate (blasted & repainted) $239.00 $50.00
12 OEM Front Rotor Dust Guards L/R LIKE NEW (priced each) $40.00 $20.00
14 OEM Console Parking Brake Cover (pwr window, sml crack, repaired) $120.00 $50.00
15 OEM L/R Door Handles (priced ea) $55.00 $20.00
16 OEM Door Lock Trim Plates (priced ea) $34.00 $8.00
17 OEM Blower Motor (tested and working, blasted & repainted) $30.00 $15.00REDUCED! - $10
19 OEM High Beam Floor Switch $9.00 $3.00
20 OEM Hood Cable Boot (from firewall) $7.30 $3.00
21 OEM Parking Brake Bracket (blasted and painted) price ea $10.00 $5.00
22 OEM Air Pump Bracket Lower W/Bolt & Nut $71.00 $35.00 REDUCED! - $25
23 OEM Alternator Support Arm Upper $18.00 $10.00 REDUCED! - $5
24 OEM Dash Ball Retainer $15.00
25 OEM Driver Side Dash Air Vents Qty 2 priced ea $50.00 REDUCED! - $35
26 OEM Passenger Side Dash Air Vent (damaged flap, missing) $5.00
28 OEM Driver Side Kick Panel W/Curtsey Light (minor damage) $50.00 $15.00REDUCED! - $5
29 OEM Rear Headliner Panels (some damage or cracks) $150.00 $25.00REDUCED! - $15
30 OEM Clutch Pedal Return Spring (blasted & repainted) $7.00 $3.00
32 OEM Misc Vent & Heater Controls $20.00
33 OEM Door Shims Qty 4 (Priced ea) $5.00 $2.50
34 OEM Blower Relay (not tested) $11.00 $5.00
36 Brake Pad Pins New Qty 4 (Priced ea) $1.50 $0.50
37 OEM Rebuilt Speedo W/New Face Plate $299.00 $225.00 REDUCED! - $200
38 OEM Rebuilt Tach W/New Face Plate $134.00 $75.00
40 OEM Tie Rods L/R + Clamps & Bolts (not org bolts) Priced ea. $24.00 $15.00
41 OEM Master Cylinder (blasted & repainted) W/Cover Power Brakes $120.00 $75.00
42 OEM R/L Plastic Head Light Guards Sold as a Pair $37.00 $15.00
44 OEM Gas Tank Filler Neck $80.00 $20.00
45 OEM Batt Ground to Frame Cable W/Gasket $55.00 $25.00 - SOLD
46 OEM T-Top Belts (harware needs rechromed) $15.00
48 OEM Heater Coil $70.00 $35.00 REDUCED! - $20
51 Spinners (not sure of year) Sold ea $41.00 $20.00
52 OEM Front Exhaust Mount (blasted & repainted) $32.00 $15.00
53 OEM Windshield Corner Trim (needs plated) $100.00 $15.00
54 OEM Hood Release Cable (mounts to hood) $39.00 $15.00
55 Chrome Air Filter Cover and Element (Eldbrock) New $29.00 $15.00
56 OEM 350 Air Cleaner Base W/Spark Arestor $75.00 $40.00 - SOLD
57 Timing Chain, Fuel, Water Pump, Crank Seal Kit New $10.00
59 OEM 350 Valve Covers 1 Refinished Priced ea $150.00 $75.00 - SOLD
61 350 Sml Block Water Pump Rebuild Kit $5.00 - SOLD
62 OEM Front Turn Signal Gaskets Pair $4.00 $2.00
63 OEM Coil Bracket (Blasted & Repainted) $22.00 $10.00
64 OEM Gas Filter Bracket $10.75 $5.00
65 OEM Clutch Fork (Blasted & Repainted) $100.00 $50.00 REDUCED! - $30 - SOLD
74 OEM Cast Iron Original 350/350 (Intake Hot Dipped) Date Code E279 $200.00 $75.00
77 OEM Water Pump Pulley $99.00 $45.00
78 OEM Pistons 350/350 11:1 $100.00 $50.00
79 After Market Crank Pulley (OEM See Above If Desired) $52.00 $25.00
81 OEM Passenger Side Healight Cover (Crack, can be welded) $299.00 $100.00
82 OEM Ash Tray Cover (Blasted & Painted) $25.00 $5.00
83 OEM T-Tops Primed (ready for paint) Price ea $100.00 - SOLD
86 OEM Valve Cover Vent Elbow $13.00 $5.00
88 OEM Wiper Solenoid Door Actuator (mounted behind tach) $80.00 $40.00REDUCED! - $25
89 OEM Ash Tray Housing (blasted & painted) $38.00 $10.00 REDUCED! - $5
90 OEM 350 Exhaust Heat Riser (needed blasted) $47.00 $10.00 REDUCED! - $5 - SOLD
91 OEM Rally Center Caps (GM Qty 4) Price ea $74.00 $45.00
92 OEM Rally Trim Rings (GM Qty 4) Price ea $90.00 $50.00 REDUCED! - $25 - SOLD
94 1/2" Crager Offsets $40.00 $20.00
95 OEM Non T/T Horn Button W/Emblem $49.00 $20.00
96 OEM Wiper Control Switch $35.00 $10.00
97 OEM Blower Control Switch WO AC $29.00 $10.00
98 OEM Rag Joint Lower $15.00
99 After Market Temp Sensor New $2.50
100 OEM Vent Knobs Pair $12.00 $5.00
101 OEM Shifter Plate $18.00 $4.00
104 OEM L/R Vent Cables Price ea $22.50 $5.00
105 OEM Fiber Center Console Panel (Blasted & Painted) $30.00 $5.00
106 OEM Horns pair. Look to be perfect but have not been tested. $60 - SOLD
107 OEM 76-77 T-Tops GREAT CONDITION Latches, Headliners, hardware, trim and Gaskets in just about in perfect shape - Both for $299
108 OEM Brake Pedal to Master Cylinder Push Rod Clevis - $3.00
109 OEM Headlight Switch Knob & Rod - $5.00
110 OEM Door Latch Striker Pair - $9.00\
111 OEM Alternator Bracket $30.00 - $15.00
