I have a 2005 corvette 6spd. The reverse solenoid needs to be replaced cause it wont turn off "shift into reverse" "part is on order". Disconnected the battery for two weeks and plugged it in and it won't start. When you press the button the engine light is on but everything goes black for a few seconds then the gauges come back on. Charged battery and jumped it and nothing. Replaced the started relay under hood and nothing. When you try to start it you can hear a click from the relay area but can't confirm if its the relay cause I've done this by myself. Tried disconnecting the terminal wires and touching them like in a youtube video and that didn't work. Help pls
Discussion Starter · #3 ·
Well thought I would post this. After changing the 'SHIFT INTO REVERSE SOLENOID" It would start and turn off. Must have something that resets when you turn it off.
Anyway solved.
