Hello Guys
I was just woundering how do you get the battery out? I see there is a bracket for the cruz control going over the center of the battery do you have to lossen that bracket to get the battery out or is there a better or easyer way?
THANK YOU ALL
Jeff
What he said. When you re-assemble everything, be sure to open and close the door slowly and ensure you've gapped the panel to the door correctly. If you bolt the panel back on too close to the door, you'll chip the paint when the two pieces smash into one another.
If this seems confusing, don't sweat it, you'll understand when you go through the procedure.
yup , just loosen it
