I bought new AC Delco side yokes from Rik's Corvettes back in 2011 and they're already shot. They have about 1/4" end play which means their splined ends have worn beyond their snap rings. I ordered reconditioned yokes from Eckler's that are supposed to have tool steel buttons pressed into their ends to prevent wear but they're back ordered at the present time.
When I tear it apart I'll check my pinion's depth and ring gear's tooth pattern and make any adjustments that are necessary. I had installed a set of Motive Gear 3.70's in 2015 and they ran quiet for the first year then slowly began whining. I'll take close-up pictures during the process so you can see how I set up gears.
