1 - 18 of 18 Posts
I'm considering various superchargers. Now this seems to be the largest supercharger that Magnuson puts out. On a LS2 motor would I need to do anything with the lower end in order to run this blower?
What hood options are out there that will work with this supercharger?
racing buddy had Century 21 in Dallas put in his and includes a warranty. you will need a BAP and he had trouble with that issue. Ill see if i can find some pics
you will need a hood and now there are way more than in the beginning, just gotta decide on one
here it is in the box
Magnuson 2300 Z06 doing a burn out :burnout:
How much difference is there between Magnuson's 1900 and 2300?
Would this supercharger require a modified fuel system?
Agent, Supporting Vendor/Tuner
Good lord! What block and what other mods?
Here's the video:
If you plan on making more than 8 PSI or use a larger engine then you want the 2300. Otherwise with a stock engine, about 7 PSI and the 1900.
Generally speaking, yes. As you increase the overall Horsepower your fuel requirements will go up. GM engineers their fuel systems at approximately 30% over the rated HP. This is mostly to ensure enough fuel if the Catalytic Overtemperature Monitor is enabled which dumps additional fuel to prevent the cats from melting down.
Great blower, but the car doesn't sound like it has a supercharger. Isn't the Magnuson suppose to put out a whining noise?
"Maggies" don't whine.
1 - 18 of 18 Posts
