Hello All,
Hope all are safe. Strange problem just started. The engine will not start. I tested the spark plug by putting spark plug in spark plug wire, grounding the metal of spark plug to engine. Very low spark, sometimes no spark. I installed a new coil and ignition control module, cap and rotor but same thing. I tested the positive wire to the distributor with multimeter and got 12 volts and when the engine is cranking 9 volts.What else could it be? Does the distributer need to be replaced? Any thoughts are greatly appreciated.
Thanks
