Installing a remote activated exhaust controller
1) Pull back carpet on passenger side
2) Pull down fuse box cover
3) Locate fuse 10A (lower right)
4) Remove fuse with removal tool provided(center of panel)
5) Install the exhaust controller in the slot you just pulled 10A from.
6) Attach the grounding wires to the grounding screw.(Screw to the left, on the frame of the box)
7) Tuck antenna wire to the right, pointing up.
8) Test it before closing up. If it works, flip panel back up, fold carpet back, and you're done.
