Vendor
aFe Momentum air intake systems are among the most popular in the company's product line. They are designed using the most up-to-date engineering tools and techniques to provide you with the perfect blend of power and protection. Recently aFe has expanded this line with a new Black Series Momentum Cold Air Intake, now available for 2015-2019 Chevy Corvette Z06. It features a custom CAD-designed roto-molded housing made from heat soak resistant cross-linked polyethylene to ensure the coolest air intake charge possible.
A large clear sight window allows for filter inspection without removal of the airbox. The housing is made out of lightweight high gloss, clear-coated plain weave carbon fiber and mounts directly into the factory location on the fender well to capture the coolest air. Momentum intakes are designed with fewer parts for a quick and simple installation. Premium stainless steel T-bolt clamps and a silicone hump coupling are used for strength and durability while also providing the most secure installation available.
Boost the performance of your Corvette's engine with a new aFe Black Series Momentum Air Intake!
aFe® - Black Series Momentum® Aluminum Black Carbon Fiber Cold Air Intake System with Pro 5R and Pro Dry S Gray Filter
Specifications:
  • HP Gain: Up to 46 hp
  • TQ Gain: Up to 39 lbs./ft.
  • Series: Black Series Momentum®
  • Filter Color: Gray
  • Tube Finish: Black Carbon Fiber
  • System Type: Cold Air Intakes
  • Material: Aluminum
  • Replacement Filter: Pro 5R and Pro Dry S # 21-90080
  • Airflow Rating: Up to 25%
Features:
  • High Quality One-Piece Roto-Molded Sealed Housing with Auxiliary Air Inlet
  • CAD-Designed Roto-Molded Intake Tube
  • Built-In Sight Window Provides Easy Inspection of Filter Without Disassembly
  • Unique (Patent Pending) Filter-to-Housing Interface for Easy Installation
  • No Cutting or Drilling on Factory Parts for Faster Installation
Includes:
  • Unique Computer Design Carbon Fiber Housing with Sight Window
  • Pro Dry S Oil Free and Pro 5R Oiled Air Filter
  • Dyno-Tuned Carbon Fiber Intake Tube
  • Premium Hardware
