Hi Guys
I was just woundering if any of you know how to free a stuck exhaust vavle? with out pulling the heads is there something that you can pour in the crank case to free it?
thank you
Jeff
stuck open ? it's bent
· Premium Member
sticking, or STUCK??.....a stuck valve does not get better... sticking is caused by heat, carbon, gunk build up, if the valve fails to close completely and seal, it soon gets burned and/or bent, and can easily bend a pushrod or flatten a cam lobe ..solvents added to oil take time to dissolve deposits, the damage will have been alrready done..
