Im getting these codes. Does anyone know how to fix? Thanks in advance
B0361 Left Actuator Feedback Short to GND
B0441 Left Actuator Out of Range
those are codes for your HVAC. does your air check out cold enough? is it the same temps on driver side vs passenger side? i'm not very electrically inclined but it sounds like the actuator is faulty.
reset the codes with the engine running
it will cycle and should fix the issue
