1 - 10 of 10 Posts
i am putting on new cat back exshaust on 2001 auto matic can i get the old one of with out cuting it off thans bill 2001 :thumbsup3:
Absolutely! Make sure to get a can of BP Blaster just in case the bolts are rusty.
If you have the right tools you can pull it off and replace with the new on in an hour or so.
the key is getting it high enough and maybe having to remove a gas tank shield
I used my lift
you need about 3' of clearance
you can back up and hang the rear off a loading dock
or as some have done , go crazy with floor jacks and jackstands
Yea,I made the mistake of not lifting mine high enough and just cut them off with a sawsall.If I could have gotten it just a little higher they would have fallen off.
cutting them really doesn't matter unless they are Ti
the stock steel ones have no resale value anyway.....
I used my lift
I used my race ramps on my 99 when I had it. It wasn't too bad. But, I quickly forgot how high it had to be of of the ground.
THIS KINDA STUFF SCARES ME
oh that is way better....lol
1 - 10 of 10 Posts
