I replaced my head light switch,which really was not too bad,but my head lights still wont come up. They will go down with the air switch.
with the bypass under the dash ? check if the hoses are disconnected, if not check the hoses for cracks ( thats the first step)
Head lights
Yes, with the by pass under the dash, the head lights close, but don't open. I'll start chasing hose, then ask for help from there.
headlight switch problem
Did you chech that the two hoses that attach to the side of the headlight switch did not wiggle off when you reinstalled the new switch. I just replaced my switch and rebuilt both actuators and replaced all vacuum lines. one of the lines slipped off the switch and I had to remove and reattach small hose. All is working fine. Maybe the same happened to yours?
Discussion Starter #5
Headlight switch
Ill look over all the air lines thoroughly, I hope it's gonna be some thing that simple.
