Our gas cap door won't latch. Looking on the inner right wall of the gas cap niche, there is a hole. It looks like maybe a threaded piece fits in it. Whatever is the latches male part is missing. What is it?
The solenoid plunger is probably stuck in. That is a somewhat common problem; happened to my car. I took the cover off on that side and sprayed the solenoid with silicone oil; no issues since.
easy fix
Do a search and you will find easy to repair procedures. Sometimes spring is corroded and cheap replacement from hardware store is neccesary.
same thing happen to me, found some instructions and replaced it myself with a new one from the dealer . quick and simple.
