You remind me of one down side to a functioning hood scoop and that is sucking in water, this would be a engineering challenge. Is there such thing as a filter that keeps water out?The Z06 setup is supposedly functional.
For most modern fuel injected V8 cars, a functioning hood scoop is tough to achieve as the intake manifold designs feed air from the front of the manifold with a TB and MAF in front of the manifold. That requires the scoop to be very far forward or the air has to make 180* turn.
This is why the Vararam design is popular. It is as close to the old school sealed forced air hood scoop as you can get.
If you are referring to the Camaro SS the 4th gen hood, it didn't provide any measurable benefit. All the fast SS's added the FTRA (or similar system) sealed to the airbox. The WS6 hood on the Firebird was a little more functional and could be modified to be a true ram air. :cheers:The SS hood is somewhat of a "ram air". It has a forward facing scoop a little larger than the Z's. And the air is then forced in front of the radiator through two ducts that also have a water containment provision. This provides cooler underhood air in the "stock" air filter area.
What does "SS" stand for anyway?If you are referring to the Camaro SS the 4th gen hood, it didn't provide any measurable benefit. All the fast SS's added the FTRA (or similar system) sealed to the airbox. The WS6 hood on the Firebird was a little more functional and could be modified to be a true ram air. :cheers:
If you owned a Trans Am or Mustang, those owners believed that SS = Super Slow. :rofl:What does "SS" stand for anyway?
Is that a film or painted over your head lights?Mine lets cold air into the engine bay but not into the filter. The filter system I have has a ruber seal to prevent the hot air coming from the engine into the filter. I get all the cold air into the engine and the vent cools the engine down about 10 degree according to the temp gage..
