1 - 7 of 7 Posts
After looking at that black C6 that was on the telephone wire, I was thinking. Does a C6 have a fuel cut off when it's been involved in a accident?
Not sure I understand the question "fuel cutoff".
The Corvette uses an electric fuel pump and electronic fuel injection, not gravity feed and as such, no power, no fuel.
After I posted my question I read it again and think I posted that question to quickly! :smilielol5::smilielol5: I was thinking some race cars have a fuel cut off so if there is a accident the risk of fire is cut down. So there are a few "holes" in my question that weren't exactly thought out prior to posting. I should get another cup of coffee! :smilielol5::smilielol5:
some cars, and most motorcycles have a sensor to measure the lean angle of the vehicle, such as being upside down and will shut off devices and not allow the vehicle to start...
Maybe the 'Vette doesn't need one but my Harley has an electric fuel pump and electronic fuel injection and it DOES have a cut-off that activates if the bike gets too horizontal. It takes a few minutes to reset when the bike is returned to the upright position. It is a safety device to minimize fuel spillage but I'm not sure if it is part of the fuel pump, part of the injectors or a separate part.
Your referring to the Bank Angle Sensor, i believe we both have 03 harleys, it is a separate device contained in the turn signal/alarm module...
Alot of cars have a re-set button for the fuel pump cut off, that is found in the trunk. In the event the relay/sensor is activated due to excessive lean angle and shuts off electrical power to the fuel pump, just press the button when the vehicle is up-righted (onto all 4 tires) and the fuel pump will receive power again.
Have not seen this used on the C6 Corvette.
1 - 7 of 7 Posts
