1 - 11 of 11 Posts
http://www.amazon.com/Sprayco-Long-Reach-Plant-Waterer/dp/B000VYGCZW
works on an A4
I'm thinking it should work on a manual
I just used a heat gun to make the tube bend the way I needed it so it would fit.
I doubt it would work with 90wt but dexron flows easily and it worked to perfection
found one at a local hardware store for 4 bucks
:thumbsup3:
This is good to know, but my question is how do you know if your trans needs any fluid and also if you add any, how do you know when it is full?
Discussion Starter #5
You pull the plug on the side of the pan
you have to have the car running , warm and level
Discussion Starter #8
FYI : the tube goes to the bottom of the bottle so you just squeeze it to make it work
1 - 11 of 11 Posts
