Why am I having engine vibration. On RPRm excellation. I ask Moron to Balance dont know if he did.
1986 C4 L98 About 10:1 compression
5.7 I assume. One piece rear main or two piece? Did he replace the harmonic balancer? Is it automatic? Did he change flywheels? More info would be nice.
Toby
Yes, give us more information. Was the flex plate replaced by any chance? It may have gotten a weighted flex plate for a 305" put on it. Or a 305" damper. Tell us the whole story and maybe we can help you. Was it your engine that got rebuilt or did you get another engine rebuilt? You might just have 2 plug wires crossed (very likely). Or one cylinder that is missing (also very likely).
Discussion Starter #5 (Edited)
Flywheel was Reground. Harmonic balancer was new before rebuild. Just pulled it off to double check. Install a used Richmond 6 speed and Mcleod 75222 clucth/bearing. 5.7 Bored .30 over big cam. Crank was switch out to a reground. And he supposedly balanced it. I hoping I had a down cylinder. Plug wire was a little Lose on # 6 cylinder. Plug looked ok. I ask engine builder he said. Rare on the Balance to be issue. Hope he right. One piece.
Questions were cranks the same Length for 350. Is there a difference in crank for one piece or two piece up front. Harmonic balancer went on crank. But crank didnt seem to go even 3/4 into Balancer. Long bolt and void? Look like it was push in up to Cam Sprocket. How you know when to stop with balancer?
How close to the timing cover is the harmonic balancer? If the builder got an older crank, the early w/2 piece rear main, I don't think the flywheel would bolt up but I could be wrong but if it did the balance would be off. But if the builder bal. the engine, the crank & flywheel should have been done together & should have been caught during the balance procedure. The only other thing to look at would be the clutch assy. Did they dyno the engine?
Toby
