The quickest way to ruin a thermostat is by drilling holes in it. On a cold winter day many years ago I decided to see how much two 3/32" (.093") holes would affect my 454's warm up time. On a 25 degree mornings my heater would usually begin blowing warm air at around 7 miles but after drilling two 3/32" holes in it my heater didn't begin blowing warm air until 15 miles and even then my interior didn't get nearly as warm as it used to.
C3 thermostats don't completely close. When examined closely you'll find there is a tiny notch in the outer edge of the center disc that allows air and some coolant to pass thru it. So even when the thermostat is closed a little bit of coolant is pumped into the radiator. Even two tiny 3/32" holes were enough to prevent the engine warming up fast enough to allow my heater to work normally so I ended up plugging them.
